Which RGB Lights (Strips n Bulbs) for Google Home?
i guess you are in luck
linus tech tips just released a video talking about the yeelight which supports google home
there seems to be a few on amazon and ebay if you dont want to mess with aliexpress for around £20 (still significantly cheaper than hue)
A video full of crap.
Start off with the Hue hub 2.1.
It will pick up most light makers(just google). Also you can buy a cheap Gledopto RGB\RGB-w controller.
Then you can make your own light strips for £6 :) Check out the Hue thread.
On my Hue bridge, I have Hue\Gledopto\Innr bulbs working.
