not a dig....btw
I’d say 4K gaming on a 27” monitor is dumb, not 4K gaming itself.
It’s pretty tricky to even spot the difference at that size but on a 40”+ monitor or TV, the visual clarity is much more evident and anyone that says they can’t see the difference is either lying or has poor eyesight.
Sure, in an ideal world I’d love a 240Hz 4K display if one is available, but currently it’s beyond daft to try and hit those frame rates unless money is absolutely no object.
Got to say I am surprised the closed-mindedness displayed by you Howling.TL;DR -
1440p144+ if he's an FPS gamer and/or doesn't have the GPU grunt for 4k - though I suspect if 144fps is managed at 1440 then 60 at 4k is in range.
1440p100+ Ultrawide if he's awesome - pretty much works with all games - stunning on stuff like Witcher and surprisingly Elite Dangerous etc. , though admittedly some games (usually FPS) crop your vertical so you actually lose vision.
4k@60 If he doesn't play FPS / twitch based games, and somehow doesn't like 21:9 ratio. Witcher 3 and DA:I did look admittedly good at 4k, noticeably better than 1440p did - but definitely didn't match my 21:9.
4k@100+ If he has the GPU grunt, best of the 16:9 choices by far
Totally not biased towards 21:9
But answering why people "chase" 4k -- it's largely marketing. Most of the people that chase 4k can't power it - but 4k has the advantage of being the next industry standard in TVs so 4k is what the average consumer will hear.
Not only have I explained that 4K image quality being better (no one disputed what I said), not only have others confirmed this, but worse you even said yourself that it is noticeably better than 1440p, yet somehow you conclude it is largely marketing? lol.
Even worse after admitting 4K having noticeably better image quality compared to 1440p, you then go on to say it did not match your 21:9. That makes no sense assuming you have a 1440p ultrawide which means same image quality as 1440p just wider. So much bias being displayed here.
Your bias is stopping you from reading what I actually put. That's fine, you weren't the one asking for input I guess - but I will elaborate. Someone like yourself, a PC enthusiast, will choose 4k for reasons like you, and I, have mentioned. "People" will chase it not through knowledge of the benefits and requirements, but because it is marketed to them so heavily. You made an informed decision, the average consumer will not. There may well be a better option for them depending on their needs and factors like GPU power - but they'll only see 4K as the option.
People chase 4k because 4k gets marketed and hyped in the main stream. That's it. I can understand people preferring 16:9 over 21:9 (well, I can't - but I'll accept people being wrong sometimes ) but they'd be much better suited with 1440p144hz. I was an early 4k adopter and was not impressed by it.
Show me where I am doing this? I must be missing something?You're completely ignoring the FPS benefit that 4k can't provide. 60Hz is not for me.
Again, "PEOPLE". Not you. Enthusiasts are a far cry from the average consumer.Sorry but that is a load of rubbish.
Here is your previous post here:
Your bias is ignoring 21:9 and attacking EVERY opinion that doesn't match your own. Even my own opinion, where I literally agree with you on 4k uses, was attacked because I didn't put 4k above Ultrawide.How am I being biased? my advice to the question was if he does not play much fps games and prefers image quality then go 4K. Where is the bias in that? I have never told someone who plays competitive fps that 4K 60hz is more suitable for them, that would make zero sense.
Attacking? Where?Again, "PEOPLE". Not you. Enthusiasts are a far cry from the average consumer.
I'd suggest you go have a calming tea and relax for a few hours, then come back to the thread.
PEOPLE? What does the average joe consumer got to do with anything? Again straw man.
Fair enough, though he also asked about his nephew which I gave a fair and balance reply to. Please show me where I attacked anyone?Thread title. No straw man at all.
Did you happen to read what I was replying to? Was there anywhere a debate where I ignored fps benefits? Nope. So don't get what you are saying.I quoted your complete post, because that's what I was referring to.
Depends. If he prefers image quality and not much into FPS games, then for sure the 4K. Otherwise go UW so you get 100hz at least.
TL;DR -
