OK guys. Back with more info.
Yes the Sapphire Vega64 Nitro+ has some coil whine. I've discovered it when playing Frostpunk, which is a city building sim.
The problem is with Frostpunk itself apparently on the first part. It's been reported that it has very bad optimization and uses as much VRAM as it can use.
After searching for a ton of stuff i found this suggestion:
Which improves the performance of the Vega 64 quite a lot according to 3DMark. https://imgur.com/a/mtLnNGh
Now the Sapphire part of the problem. Indeed the card has coil whine.
At 99% utilisation of GPU and VRAM is decently loud and surpasses the fan noise.
In Witcher 3 with FULL details (+Freesync & VSync but w/o the nvidia hair stuff) it only goes up to 30-50% gpu load or so. And the coil whine is not that harsh.
Anyway because of RMAing this card will cost me ~90 GBP to send it to UK and back, i will keep it for a while.
Try those settings mate and let us know how it goes.
Bear in mind if you play old games like Elder Scrolls online, SWG, right click where it says State 7 Max and select "Minimum"
But I would advice to make profiles for those games and not do it on the generic profile as it will keep the clocks high even on desktop.
