Best ITX Mboard for Ryzen 2700x with Optical audio out?
19 Aug 2016
looking to put together an AMD SFF build in the next month or so but the Mboard range seems slim pickings. Hoping to jump into Zen 2 when that becomes available next year so figure I should invest in the best ITX Mboard I can right now however there are so few options compared to Intel.
Apart from needing an Optical audio out port and NVME M2 slot I am not that picky. Not fussed by particular brand or cost.
Any recommendations? Thanks.
I only found 1 ITX motherboard with an optical output on it, all the others had very basic audio outputs, seems to have a very good audio on it too: https://www.overclockers.co.uk/asro...-am4-ddr4-mini-itx-motherboard-mb-16a-ak.html
M.2 slot is around the back
https://www.asrock.com/MB/AMD/Fatal1ty B450 Gaming-ITXac/index.asp
Many thanks, much appreciated. So best I can hope for seems to be a B450 board. Surprised there aren’t more 470 choices. Optical or not.
Have you considered using a USB solution? This would give you a much wider range of motherboard options, the ASUS X470-I with Dual M.2 slots lacks a digital out but I rather feel that using an inferior motherboard option that won’t give the sound quality you probably want anyway:
https://uk.creative.com/p/sound-cards/sound-blaster-x-fi-surround-5-1-pro
