How many of you have working 2080ti cards?
28 May 2007
Saturn’s moon Titan
as the title says I’m on to my second 2080ti .somebppl have had 3 lol.not good for nvidia at all.
My MSI Ventus 2080ti has been a stellar performer with no issues at all, slight coil whine for the first couple of days but appears to have burned in perfectly. Over-clocks like a beast too.....
Here's hoping i haven't cursed my luck but no complaints from me on this topic.
What’s the noise and thermals like on this card mate .
Just wanna mention i have the OC version.
Bit of coil whine for the first couple of days but seems to have burned in fine. Set a custom fan curve in Afterburner so no audible fan noise and doesn't go above 70c whilst gaming. Got a +195 on the clock and a +650 on the memory.
All in all i am very happy with the performance of this card.
Also, the custom bios for the reference models works with this card, unlocks the power setting to 130% but i am happy enough with where i'm at.
My replacement has been working flawlessly. With the revised EK block instructions the pads now on the coils have eliminated all coil whine.
My first 2080ti worked at first except for in GTAV if I had any grass setting above normal (which is no extra grass) the performance would tank (I thought this was a driver issue, but turns out it was first signs of bad card). With the new 2080ti grass is not a problem.
Zotac AMP 2080Ti here.
No problems at all and doesn’t go over 69 degrees even with the fan on auto.
Can only get +165 on the core, suspect it’s a power issue rather than heat. May flash the BIOS at a later date, if I have the balls for it.
Just curious, did your card stop working after the performance tanked?
