Did you not check what the price was when buying or something then?![]()
It'll be no where near 10GbE with 4 WD reds in RAID 5.I'd be very interested in the 10gbit performance. I sell quite a few QNAPs with SFP+ cards, but have not had the opportunity to actually test out 10gbit with them.
Nate
Not sure which order of events this happened, but in one night it seems my oil pump and/or oil pump chain tensioner failed resulting in loss of oil pressure causing the rod bearings to go, or possibly the other way round.
Had to mullet over all my options and keeping the car seemed silly, but I'm invested in this thing and the time and energy put into it the last 4 years to make it mine forever would have been to waste so decided to replace the engine and have Redish Motorsport do what they do best. Needless to say, new bearings are going in the new engine as well as VANOS overhaul and everything being thoroughly inspected.
Pro tip for anyone buying these cars, ignore the BMW oil service interval and have an oil service done without fail every 4-5000 miles or once a year whatever comes first. And between 60 and 80k mileage, have the rod bearings replaced. I used to think sticking to the BMW guide in the service book was perfectly fine. It is not for these cars.
True but it will be a lot better than with 1GbE now that bottleneck has been eliminatedIt'll be no where near 10GbE with 4 WD reds in RAID 5.![]()
Yup. It'll still be 1Gbit to my regular LAN, but that's just administration traffic, TimeMachine and Plex. 1Gbit will be ample for that.True but it will be a lot better than with 1GbE now that bottleneck has been eliminated![]()
That what I was thinking..It'll be no where near 10GbE with 4 WD reds in RAID 5.![]()
You're going to love thatMmmmmmmmmmmm
I feel my 65" OLED is one the best things I have bought for a long time..
I do believe these can do 120Hz output at 1080p and maybe even 2560x1440. Tasty.Mmmmmmmmmmmm
It's not a case of needing 10GbE, it's more a case of needing more than 1GbE. Any decent HDD made in the last couple of years can saturate a Gigabit link, multiple in RAID can saturate it by three times.What Hard drives would need 10GbE speeds ?![]()
Guessing it would be much faster if multi systems are transferring stuff across it at the same time..
I looked at 10Gb and just went with a couple of 1Gbps LACP connections instead.
Fair enough. A lot of people don't realise this. Until SMB multichannel matures that is.Yes, I'm aware of that, but thanks anyway. I have 1Gbps Internet at home - main reason I setup LACP was to give me the capacity to multiple destinations, and t'other way around.
