- 9 Mar 2008
- Glasgow
Hi, looking for some input before shelling out on a potentially unnecessary upgrade. I've had a 1080ti for over a year and never been very pleased with it. Certainly, attaining higher FPS than my old card (980ti) but the experience has been worse. I kept getting constant stutters while gaming to the point it was basically unplayable. My average FPS would be fine, but it would occasionally tank to fps in the single digits. I RMA'd the card to EVGA and got a replacement, which seems much better, but it is still suffering from the same problem, just not as badly.
I mainly play fps games and notice particularly when I ADS that’s usually when I get a stutter. I can play the likes of BF5 etc and a million things can be going on screen and no issue, but it always seems to tank when I complete some sort of input (ADS being the main one). Even watching youtube videos while stutter from time to time even if the video has already downloaded. I also get a similar issue with my VR headset (HTC vive) at the start of a race as I set of, I get a brief desync and the IR camera's need to re-establish a connection and then I'm off. Again, I can have 20 plus cars on the grid and the framerate is typically fine but will tank seemingly randomly when I am out on my own.
I have a 5820k running at 4.375Ghz (35x1.25multiplier) and this is the max I can get out of that CPU. 4.4 and indeed 4.5Ghz will always crash no matter what voltage, multiplier or whatever else I have tried thus far. However, for that brief bit of time it does run on 4.5Ghz, it seems to work OK (no stutters). The temps peak at about 70 on the CPU, usually mid 60s. I also get the issue if I put my CPU back to stock settings.
I've looked around and the general concencious from my googling is a 5820K should not be holding back a 1080ti yet here I am...…….
Does anyone have any suggestions before I cut my losses and upgrade the CPU/Mobo?
NB, when my card was away for RMA, I went back to the 980ti and it had no stuttering issues.
Full spec:
1080TI
5820k @4.375Ghz
16GB RAM @ 3000Mhz
1000W Antec PSU
1TB NVME SSD
2x500GB SSD
2x3TB HDs
Thanks!
Full spec:
1080TI
5820k @4.375Ghz
16GB RAM @ 3000Mhz
1000W Antec PSU
1TB NVME SSD
2x500GB SSD
2x3TB HDs
Thanks!
