Good Morning
Sorry to bother you but i'm really looking for some advice regarding my computer upgrade and i'm hoping you might be able to help me please .
At the moment I run a Ryzen 1700X on a Taichi board with 48G Ram I use Virtual machines a lot and can now have up to 20 running at one time .
Of course this maxes out my PC so i'm looking to upgrade to a thread ripper but i have a few questions i'm really hoping you could answer and guide me with please ?
I'm looking between the 1950X or is it worth paying the extra to the 2950X ?
I'm a big fan of the Taichi board i use at the moment but I've noticed OC have no stock atm and if i did get a Taichi X399 board would it run fine with those CPU's?
My next question is the memory issues would either of these memory sticks work on the system ?
DDR4 Quad Channel - (2666MHz) 64GB (4x16GB) Corsair DDR4 Vengeance LPX Black PC4-21300 (2666), Non-ECC Unbuffered, CAS 16-18-18-35, XMP 2.0, 1.2V
Or
DDR4 Quad Channel - (2800MHz +) 64GB (4x16GB) Corsair DDR4 Vengeance LPX Black, PC4-24000 (3000), Non-ECC Unbuffered, CAS 16-20-20-38, XMP 2.0, 1.35V
I've checked on the Asrock site for memory the model number for Corsair Vengeance LPX 64GB DDR4 3000 MHz RAM/Memory Kit 4x 16GB 64GB (4x16GB) Corsair DDR4 Vengeance LPX Black, PC4-24000 (3000), Non-ECC Unbuffered, CAS 16-20-20-38, XMP 2.0, 1.35V is Manufacturer code: CMK64GX4M4D3000C16
On the site Asrock site it has this :-
If not what would you recommend was hoping for something around £475+ price for 64Gig
I'm also running a old 750 W ( 7/8 years old) Corsair PSU which i'm looking to upgrade too.
Not sure what the BitFenix Whisper power supply 850W 80+ Gold are like and same with Seasonic FOCUS+ Gold 1000 watt power supplies ? Always used Corsair .
Last question ( sorry )
I run a AIO cool master atm 120mm fan push pull want to do the same on the thread ripper but seem to only find the Corsair Hydro Series H80i V2 All-In-One Extreme Performance CPU Cooler with 120mm Radiator, 2x 120mm Fan, Intel/AMD, TR4 ?
Does this come with the bracket for the TR4 ?
Thank you
Or
Thank you
