How long do your laptops last?
19 May 2012
I bought a retina MBP 2014 and its still going strong (4.5 years).
How long in general do your laptops last you?
My previous laptops before Macbooks [windows] lasted usually 1-2 years before issues started arising. I'm tempted to move to Windows again once the RTX 2070 starts featuring in laptops as I'm not impressed with the direction Mac have taken.
Currently using an rMBP late-2013. Had a battery swap under extended warranty so should have another 3 year life at least. I'd probably still be using my late-2011 MBP had it not been replaced after GPU issues. Previous MacBook Pros lasted 3 years each. Probably won't buy another as they're vastly more expensive than they were and are a sealed unit with reliability issues. The late-2011 was £1400, similar machine now is nearly double that.
Backup plan is a three year old quad-core ThinkPad, bought refurbished for under £300...
Bought a Dell Vostro in 2007
Put an SSD and 4Gb of RAM in there a few years back. Upgraded to Windows 10.
Still does everything I need in a laptop with no fuss and the battery even still lasts well over two hours. Very impressive.
Finally stopped using a Dell 9400 from 2006 this year. Still working, just too slow. We also have a XPS M1330 still in use. They are about both 12yrs old.
2011 mbp still ticking over. Battery replaced but has the known overheating gpu issue. Missed the cut off for board replacement but wife uses it for clothes window shopping only so really not bothered! :D
x2 dell AW laptops, both fried mobo within a few months.
Now on an asus zeph. Going strong months later, long may it continue!
My current laptop is near 6 years old and still going strong - though these days it doesn't get as much use as my laptops did in the past due to the capabilities of more recent Windows 2in 1 tablets.
IIRC the Clevo custom unit I had before that lasted about 2 years before the GPU memory died and some other laptops haven't lasted overly long.
Currently on 1.5 years with my Alienware 13, would expect to get another 1.5 years out of her at least, the 6700HQ + 1060 6GB combo will be fine for 1080p for quite some time as I am not a massive gamer.
i have a dell xps from 2008? booted it up a few weeks ago and still works. my cousin uses it for word processing, watching movies etc and still works no issues. rnning windows vista i believe too
My laptop has always been entirely secondary use PC, so they don't get much of regular use and still less anything which could be considered heavy use.
At least for what can be considered resource demanding for that moment.
First one was Acer Travelmate 803 which I think I had for seven years, after that it went to sister who used it for IIRC 3+ years.
Now I have (as model 10 year old) Lenovo ThinkPad T500 bought IIRC ~8 years ago.
Because of problems in showing higher res video taken with camera and drone I've now ordered X1 Yoga to replace it.
For light use like word processing and web surfing it could certainly be still perfectly working for years with few easy/minor updates.
With proper handling it certainly wouldn't be breaking mechanically soon.
And Lenovo certainly didn't put any sponges inside it to collect humidity and corrode PCB, unlike some other company.
Of course if you buy some cheap model made from the cheapest materials, it might start rotting by itself even in the most careful use.
But quality laptop can certainly last long time mechanical construction wise.
Also if properly designed and built electronics shouldn't fail fast in normal use.
Though of course cooling system would be good to clean once per some amount of usage hours, especially if environment isn't very clean.
Even if CPU can throttle itself to prevent "core meltdown", dust could wear down fan and unnecessary high CPU temperature shows in temperature of surrounding components.
My last laptop lasted about 5 years, gave it to my parents but it's showing its age with a C2D. My new laptop (specs in sig) I expect to last a few years then will need an upgrade for gaming.
My 2013 Thinkpad T530 has an i7 2930QM and 16gb RAM so is almost as fast as my desktop still. My other 2014 Thinkpad T440s is build for more portability and epic battery life so it's just a low voltage i5 with 12gb RAM. But it's still perfectly usable for mobile software development. I may consider selling one soon as I don't need two in addition to a gaming desktop. But they are still absolutely fine in 2018/2019.
As I don't game much I've even considered using the T530 docked to multiple monitors as a desktop replacement.
Dell XPS L502X purchased back in 2010. Built like a tank and still looks like new!
I have knocked it off a table a couple of times, spilled a mug of tea over the keyboard and speakers. I swapped out the keyboard for a new one (even though the original still works) and I thought the speakers were broken - however once they fully dried out, one day burst into life. The screen remains excellent and remains a great screen for films/games etc. It plays games really well, obviously not newer titles, but even older demanding games - are perfectly playable. Still fairly sprightly with Windows 10 (albeit the SSD I later installed helps!)
The battery even when new was useless (get about 30 mins now) and never really portable (quite weighty). Nevertheless, still an amazing bit of kit and one of the best purchases I have made, still use it now.
I bought a samsung series 9, the cheaper one, in 2013... and its still great. One of my best purchases. It has occasional use only really. Im hoping for another few years yet!
Ive been using a 2007 macbook.....it still works, unfortunately most software doesnt! Hence why im now looking around. Prices of new macs are so expensive, but the life is legendary. I used to use windows but got fed up replacing every 3 years..
Any tips?
Ive been using a 2006 macbook.....it still works, unfortunately most software doesnt! Hence why im now looking around. Prices of new macs are so expensive, but the life is legendary. I used to use windows but got fed up replacing every 3 years..
Any tips?
Do you need any specific software? If not then try Linux on the Macbook and modern stuff such as up to date browsers will work fine. Or Windows. There is nothing technically stopping stuff running on it other than Apple deciding they want you to buy something newer and preventing you upgrading to the latest OS.
If you do change the laptop then a used T series Thinkpad will give similar epic life.
I need to run a certain 64 bit piece. It wont work on 32 bit on the windows partition and wont work on the mac system, so alas, its useless now?
Whuch CPU does it have? Wouldn't it be a Core 2 Duo? I thought they were 64 bit processors? Does Windows 64 bit not run?
Also what software is it?
