Corsair RGB to Molex or equivalent? Without buying Controller
22 May 2010
Minibotpc
As per title, is it possible to connect the Corsair RGB element of the fans without buying the controllers for them?
Was hoping there was a molex/sata adapter or RGB compatible splitter?
Cant seem to find anything.
Help is much appreciated.
Thanks
No, they’re digital LEDs, they need a controller of sorts to work. Corsair RGB fan triple packs do come with a controller of sorts through.
Do they sell that specific controller on its own? The ones ive seen are rather expensive...
They do. Rgb hub with commander pro if you need the extra fan and usb 2.0 ports or rgb hub with lighting node pro if just for rgb.
