Hi Guys - Apologies, as I appreciate there are a tonne of threads on this, but they all seem to be from people who have needs ...not quite the same as me!
So here is what I have:
i7 4770K @4.5Ghz EK Custom Loop
16GB 2400Mhz RAM
RTX 2080
1440p 144Hz Monitor
I have had my i7 4770k from launch and have sweated it solid for 5+ years. I recently upgraded a pair of GTX980s for a single RTX2080 as I got a decent resale on ebay just prior to RTX launch. I upgraded as I was generally fed up with the lack of SLI support in some games. Felt it kept getting nerfed with each driver update.
SO – I right now, I mainly play @1440p… BFV, with a side of PUBG and SWBF2. I am generally happy with frames in normal use ~120 in open maps dipping to ~100 in busy maps. When I flipped to DX12, upgraded to the new December drivers and ran DXR on low, I had mixed feelings with performance.
I get very playable frames from 60-80fps dependent on map, which is ok for DXR right now. BUT i get huge frame drops, randomly during explosions, or viewing down a scope - it can drop to 20 fps causing really bad stutter.
SO – is it worth up grading my CPU?
I appreciate the higher res you go with a high end GPU the less benefit you get – but are these frame drops a product of an old CPU?
If I get a new CPU it means a whole new platform, so Mobo + Ram. Would I have just been better spending another £400 on the 2080ti!?
Most of the CPU reviews are redundant as prices have shifted a bit – I am also INTEL all the way – no team red, sorry.
These are prices right now and I can stick my EK block on so cooling isn’t an issue.
9900K £570
9700k £400
8700k £400
8500K £240
OR – should I wait until next year, turn DXR off and hope 10nm comes soon?
Thanks.
16GB 2400Mhz RAM
RTX 2080
1440p 144Hz Monitor
9900K £570
9700k £400
8700k £400
8500K £240
Thanks.
