Where to buy parts online ?
22 Feb 2014
I am bit out of touch with regards to sourcing car parts online at reasonable prices.
I have focus ST225 front calipers on my Mondeo and I need new disks and pads.
I bought some disks in February of this year off ebay (new) for £89 and they warped fairly soon after.
so where are the best places to look for parts (tried ebay/gsf/euro carparts so far) ?
any recommendations on disks & pads ?
Ideally I want decent grooved disks and some fast road pads, but nothing that needs heat in it to start working properly, EBC green/red stuff have come up quite a bit whilst searching but hey are quite pricey at just over £100 for a set of fronts, having said that I don't know what is considered reasonable for set of pads.
Have a search for ECP codes, they tend to do big discounts at certain times.
Oh and I used Yellow Stuff on my MX5, they did me well on road and track.
as commented German sites often have good deals - despite typical dhl costs - used Autoteile Supermarkt last time,
often need to search with german words on de ebay.
on again *TODAY* use ebay 10% discount - last time for oil purchase 8L fuchs supersyn 5-40 ~£33 + filter
I'm not sure whether it's pad choice or those discs but at 9k miles on those paired with EBC yellows they need replacing
I'm on EBC yellows too, I think they've done around 10k miles now, one track day plus santa pod with over 350bhp behind them, the pads are hald worn and the discs don't even have a lip on them yet. I'm not a heavy/late breaker though.
That's also going to be a factor, I've done 4 days at Curborough in that time, it's fairly brutal on brakes and I am heavy on the brakes.
I'd still use them again though, perfectly happy with their performance and they're cheap enough that replacing them every 3 years or so is hardly an issue
GSF when they run a 60% discount have been very competitive for Brembo discs on my car. Cheaper than ECP,CP4L with a discount code on Pagids.
As I found out recently, a lot of the smaller things (not all) are actually cheaper when you buy them in store from ECP! Done a few click and collects in the past and then seen the price in store cheaper than the prices even including the discounts!
I always use ECP, eBay or a small motor factors in the village.
ECP is usually cheapest for me, but eBay comes close or better in rare occasions.
For heavy things, ebay can be at a disadvantage due to postage costs.
Any of you guys have a link for this ECP place
As Googling for "ECP" didn't seem to help (Emergency Contraceptive Pill (ECP) Don't think that was it :p...
Euro Car Parts (eurocarparts.com) or CarParts4Less are the same company and often cheaper (carparts4less.co.uk)
