- 5 Aug 2006
- Derbyshire
Hi all.
I have bought a Sanus Viewpoint TV bracket from Screwfix.
It comes with two types of mounting methods:
1) Screw into 2"x4" joists (included plastic plugs not needed)
2) Screw directly into concrete (included plastic plugs needed)
Given that my new build has Thermalite blocks with an air gap before the plasterboard, neither of the above are suitable. As I have photos of the house before plastering, I think that the Thermalite blocks start 25-30mm behind the surface of the plasterboard.
I am thinking just buying some form of ~80mm long expandable bolts. If I buy wall anchors that expand in the middle then I must be confident that the centre of the bolt is deep within the Thermalite blocks.
What wall plugs do fellow DIYers recommend? I'm a firm believer that going overkill on wall fixings is the wise and wish to buy tomorrow in-store.
