I did post about this when I first moved into our new place back in August but had other more important things so put it on the backburner, but now I want to get my speeds sorted and make the most out of what I am paying for.
Supplier is VM with the superhub 3.0 I get 200mbps 8-12ms wired. My phone gets 200mbps 12ms over wifi anywhere in the house over 5ghz wifi. only place it drops from 5ghz to 2.4ghz is the garden which the speed then drops to 100-120mbps 20ms.
My pc however only get 90mbps 20ms max over wifi, the wifi card I am using which i think may be the issue is this; TP-LINK TL-WN881ND 300 Mbps Wireless N. My pc is around 12ft away and on the floor above.
Powerline adapters are not feasible, as already owned several 300mbps adapters and virgin gave me some 1200mbps adapters for free both of which get the exact same speed of around 80mbps max, less than my wifi which leads me to believe the circuits in the house are a mess (60's).
Running an Ethernet cable is a no go as; 1)I rent, 2) I already tried and its an eye sore crossing my hallway no matter where i route, 3) as I rent I'm not going around drilling holes especially outside so cant even go out and come back in.
So am I correct in thinking my issue is my wireless card in the pc? I don't know a great deal when it comes to wireless specs so completely unsure of what I need to get the best speeds and lowest ping, my goal is to get as close to 200mbps as possible with lowest ping possible on my pc. As I'm not clued up I've no idea what to set for a budget as if something for circa £50 gets my 180mbps with 12 ping I'd be happy but if something for £100 gets me my full 200mbps with 8 ping id also be happy.
Basically what would you guys in the know recommend?
