Tidal on Mac but control from iPhone/iPad?
Man of Honour
21 Feb 2006
I have both Spotify and Tidal and though I much prefer the Spotify interface I can't get past (to my ears) the better sound quality like for like I hear in Tidal £19.99 a month subscription. So I am going to bin Spotify and fully commit to Tidal! I have a Mac Mini running the Tidal app as my primary source connected into my DAC, but I seem unable to control the OSX App from my iPhone or iPad, which is simple to do on Spotify.
So what am I doing wrong, or is this feature not possible on Tidal? Also I had to send my DAC back to NAIM the other month due to a fault (now back) and what it also clearly evidenced to me is what a HUGE difference the DAC makes, but that's a whole other discussion.
Advice most welcome :D
Not possible, not directly from phone/tablet. Main reason I binned it. Can work around it but involves adding more hardware, eg, OPPO 103 etc.
I ended up on amazon music unlimited. Deezer I've not tried...
P.S. Get a demo of a MSB Platinum DAC. ;)
That is a real pain in the ass! It is far easier as you know, to sit and playlist select from your iPad from the sofa. Poor from Tidal to not support that.
Indeed. Shoulnt be too hard to make an app for it, would expect it with the premium they ask for the service. Might be worth sending them an email to see if anything's in the pipeline....
can't you run a remote desktop from your ipad ...
or use a laptop from your sofa with usb dac , make up some long HQ audio leads ... listening to tidal now
I've not used if for tidal, but RDP should work OK though - artist completion would work fine, and who cares about videos.
I think it has become a must have feature if you have multiple playback devices as I do. I want to be able to move between a room and chose a different device to carry on listening on.
https://roonlabs.com/
Not cheap but I love it, you can control Tidal and all your locally stored music all from a phone or tablet
would roon give you access to the tidal master library ?, or,
is it just casting (eg to a chromecast audio) the 320kb/s stream as you can already do from the chrome browser accessing tidal .... i could not see from their web-site.
I could understand if they want to ensure drm protection is good for the best quality streams, so preclude playback on a remote device.
edit: saw tidal now available via plex which can be controlled remotely
BUT for the master mqa 96khz tracks/24bit tracks cant see if these could be accessed (by plex or roon) , but flac 44.1/16 probably can
personally don't have an mqa dac, so that has to be unfolded in software on my pc.
edit2:
A TIDAL subscription through Plex will be identical to one purchased elsewhere (such as through TIDAL itself), barring a couple of minor differences:
  • While the HiFi plan does have access to lossless quality music in Plex, it does not have access to “master-quality” (MQA) music when played through Plex. (You can still access MQA content in TIDAL apps directly.)
  • You cannot download TIDAL music to Plex mobile apps for “Offline Mode”. (You can still download tracks for “Offline Mode” in TIDAL apps directly.)
no other opinions on whether plex will fix access to 16/44 flac material ? as opposed to $150 for roon ..
need a plex pass though, or, buy your tidal subscription, through plex
saw roon does now do mqa
https://www.audioxpress.com/news/roon-labs-releases-roon-1-5-update-with-powerful-mqa-integration
excellent description
https://www.audiostream.com/content/mqa-decoding-explained
An MQA encoded file can be played back in four ways; with no decoding, software decoding, hardware decoding, and a combined software/hardware decode.
If you play back a 24-bit/192kHz MQA-encoded file using iTunes through a regular DAC (i.e. a non-MQA DAC), you will get a 24/48 file.
If you play back a 24-bit/192kHz MQA-encoded file through an MQA software decoder like Tidal HiFi, Audirvana, or (soon) Roon, and you are using a regular DAC (i.e. a non-MQA DAC), you will get a 24/96 file. A software decoder does not offer the ability to 'unfold' the original file to resolutions higher than 24/96 (or 24/88.2).
If you play back a 24-bit/192kHz MQA-encoded file through an MQA-enabled DAC, you will get a 24-bit/192kHz file. If you are also using a software decoder like Tidal HiFi, Audirvana, or (soon) Roon, you can have the software decoder perform the first 'unfold'.
