Gigabyte X470 Aorus Gaming 7 Wifi nvme drive?
19 Oct 2002
Woolyback Country
Quick question
Which of the 2 slots do i use to install:confused: 1 nvme drive?
Can`t seem to find a definite answer in the manual :(
Got it all running ok with the 8pack 3600 ram and nvme drive outside of case atm
Bios is F3
Should i update to latest before i start loading all my crap back on?
As in is there any problems with later bioses and can i flash back to previous if i do?
Sure i read somewhere that `some` mobos would not let you flashback:confused:
Bios is F3
Yes you can flash back and forth the bios, there's a new F6 bios for the board which might help with ram stablity. I'm still on F5 which has been stable for me, the bios also adds NVMe configuration in the bios.
