Images of items I have purchased (except trainers)
27 May 2007
Front of the monitor
Bought these cards a while back, first the power color but then decided I didn't want to have a nVidia in my spare machine so got the Sapphire as well, which now is resting in my main machine though. :p Maybe a bit overkill for a spare machine but fells better having just AMD, since it just works ! :p
And yesterday I got my new mobile phone, a Nokia 8 with 128 GB memory and 6 GB ram. Was cheaper to buy that one then the 64 GB version over here. :eek:
Man of Honour
20 Sep 2006
Got this for the living room. It's bloody
Sorry for potato pic.
Man of Honour
20 Sep 2006
Could you take a picture once installed? I'd quite like to see as I'm contemplating one of these
Yeah of course, I am going to try and fit it tonight. Just worried about the weight, it's 5kg or so and my ceilings are plasterboard. Going to see if I can locate some wood to screw into close to the existing lights which are the bog standard single white cable hanging down onto a lamp.
Caporegime
1 Nov 2003
Lisbon, Portugal
I have hung a projector and screen on plasterboard ceilings, the trick is toggle bolts. Can get them from B&Q :) - they spread the weight massively.
29 Jul 2011
Near Northants / MK
Take a look at Hollow Wall Anchors :)
To be fair, you'd probably be fine with the standard corkscrew fixings.
Caporegime
1 Nov 2003
Lisbon, Portugal
Kudos to Phillips... getting men interested in interior lighting. They must be laughing their asses off all the way to the bank. :p
Lighting has the biggest effect on the mood of a room, which has a direct impact on your impression of a room and the mood it sets when inside it.
Yes the Philips Hue gear is expensive, but undoubtly, its excellent at what it does.
