I’m using a H150i and it barely cools the 9900k at 5.1ghz (85-90 degrees under full synthetic load).
At stock your h80 might do it in gaming load.
not gonna happen with a custom loop.I want minimum maintenance
for just a cpu loop (ie: pump, res, 360mm rad, cpu block, tubing and coolant) probably £200-250ishWhat sort of cost am i looking at here?
No it won't be OK.... Unless with 5000rpm fan... Then it's fine...Has anyone had experience cooling this CPU with this cooler? Is it man enough for the job and will OCing be OK?
Thanks buddy. I was looking at doing the GPU as well and it seems that ill need a 360 and 240 rad... does that sound about right?not gonna happen with a custom loop.
Cheers 8 pack, always a man of little words with maximum impactNo it won't be OK.... Unless with 5000rpm fan... Then it's fine...
Quite agree! Do you think the 115i Plat will be man enough with some OCing and mainly gaming?No need for long winded in many cases incorrect responses... Not in this thread but in many... By people who simply have no experience of testing passed the sample they own...
I have an optimised FD R5 case that maximises airflow in the location it is situated. Im almost certain that the case airflow will not further impede any CPU temperatures and this cannot be improved. I understand that the case will still have a bearing on CPU temps but im just saying that i will not be able to improve it.As with all cooling, (as 8pack correctly implies with his delta fan example - 5000rpm), it is not just cooling the CPU directly, it is getting the heat away from the case.
Good case airflow and fan combinations are key to this.
And how does that compare to the capacity of the H80i V2 with its thick rad and push pull fan config?The trouble with the Corsair AIO's is the rads. They're cheap and the fin count is too great for the vast majority of silent fans.
A good 120mm custom loop is night and day between a 120mm AIO.
A 120mm Black Ice Nemesis radiator with a basic pump/res combo and block will easily outdo even a 240mm AIO.
http://hardwarelabs.com/nemesis/gtr/gtr-120/ - 500w capacity on a 120mm radThey really are that good.
Well i guess that answers that one thenI have a push/pull H80i V2 after downgrading from a custom loop - it's awful in comparison.
Again, the Corsair thick rad with high fin count is a terrible combination and more of a bottleneck than an effective cooling solution.
Well i guess that answers that one then![]()
See previous post:Quite agree! Do you think the 115i Plat will be man enough with some OCing and mainly gaming?
280mm h115i platinum on an overclocked 9900k. 5ghz all core with 1.31v, and still reaching 89c! toasty!
see 11:10
yea i was aware of this but this vid was about maxing the CPU and gaming will not do this. What sort of temps would we see at gaming levels (yea i know different games use difference amounts of the CPU). Like a ball park figure. I wouldnt want it above 80c really while gaming.See previous post:
an aio cooler is 50-75% as efficient as a custom loop
I am not disputing this, I am just surprised. Why is this the case? I thought a purpose built, short tube AIO without crazy bends would be equal to a custom loop with same size rad.
I did Google it and most pps were saying AIOs are on a par, have shorter lives but most importantly - look crap in comparison![]()
