Kitchen isolator switches
13 Jan 2003
We prefer MK switches due to the design and with a new kitchen build we have two single isolators (fused switch without neon) and we have two usb double gang 13A and a non-USB double gang.
The electrician has combined the remaining 16A oven, gas hob+hood and fridge into a single three gang isolator. He is pushing TLC supplies to provide but I want a matching MK design.
Looking on screwfix, MK do a grid switch that is either 3 or 4 gang into the space.
This allows a grid 20A oven switch and two 13A switches but maintain the design.
Does anyone know if isolator switches for the fixed connection requires a fuse?
The electrician has put the kitchen sockets on their own new ring and run a new line for the 16A oven both to the consumer box (he is replacing this with a metal box at the same time) so both would be on their own trips.
sounds a bit risky having fridge and oven isolators adjacent ... had that in a previous property .. I usually turn off oven when not being used and don't want to turn off the fridge accidentally.
don't really know but - won't there be a single fuse in the 3gang isolator for all the devices?
These will be wall mounted above the worktop on the other side of oven & fridge.
The previous cooker isolator (big red switch style) didn’t have a fuse for the cooker. However the isolator 3-gang would not have any fuses - I assume the ovens don’t run fuses at the point of the wall fixed connection (it would have to be a larger non-14A fuse anyway).
Searching doesn’t specify a need for fuse but an isolation switches is not so much for safety (trips and fuses) but to disconnect when not used for a period.
As long as the appliance is running from a plug head with sutible fuse installed and it doesn't bother you dragging them out if a fuse does blow then a grid with isolators is fine.
The oven will be on it’s own trip and I don’t think ovens are normally fuses behind or on the insulator.
Given the weight of the oven it’s not a simple pull out to change the fuse!
Manufacturers instructions will stipulate if the oven needs to be fused down or not. If it’s not on a plug head from factory then it likely won’t need to be fused down.
Why turn it off when not in use?
several hobs I've owned have dials where you might fail to set it to 12oclock off, in the final dishing up/everything done phase.
it's also quicker than having to turn off both grill switches, and, if i need it again (2nd round of flat breads) flick it on again.
... mainly just child safe and precaution against knocking knobs, if doing other things on (flat) hob top.
