Glad it's not just me who thought that!Not sure what this whole thread is about when the answer is in the first post lol.
Me....lol
Does that download the .iso image to a certain folder then format the USB drive and extract the files to the USB then delete the original .iso file . Or does the .iso image remain after the USB has been made ?The MS download tool has a USB drive option
Do you use the optical drive to install Windows ?
I have never used that tool to make a USB. I think I may have to test this out.
urrrrrr....Never done that and have never had any bother booting from USB...
Sorry but it's never going to boot without actually putting a bootsector onto it:
bootsect.exe /nt60 <drive letter>:
It does both, it gives you the option to select a USB drive, or download to an ISO. You can select between downloading 32/63bit or both together. It's a foolproof little program and why anyone would want to mess about with rufus or diskpart (both brilliant tools) when there's a dedicated program from MS to do the job, I don't know!
Always.
I have just been messing with that Microsoft Media Creation Tool.. (MCT)
I have done two tests.
Firstly I just downloaded a .iso image. It took 6 minutes to download.
Secondly I used the tool to make a USB. It did not download a .iso image but just downloaded files to my chosen USB. The file system is FAT32. This took 10 minutes to make, which I feel is pretty fast.
I did notice though the MCT brought up ALL of my drives so care should be taken there to select the USB, double checking the drive letters before proceeding.
I noticed the .iso image is smaller than my latest MSDN image and the difference at a quick glance is the install.wim file is actually a install.esd file. Which is a more compressed version. I have the inclination to convert this install.esd to a .wim and compare the sizes then.
It is the first time is using the media creation tool, first impression is its pretty good.
I have yet to do an install with this MCT made USB but i will do later, just to see.
I feel it fare now to download the latest Rufus and see how long it takes to make a USB with the MCT downloaded .iso image.
Then I suppose i should time how long it takes for Diskpart to format the drive and how long it takes my machine to copy the OS files over. I will use the MCT .iso image files.
I will make sure to use the same USB 3 drive for the testing.
Speed is not everything though.
It is when it comes to operating systems, like Windows.
I'm not suprised. Literally the first reply to the thread gives a tool that does everything they need in one yet this has now devolved in to a 39 post thread offering convuluted alternatives and arguing which is best Albeit in a civilised manner.The only person not really saying much seems to be the OP.
