Yep, You'd have to be out of touch with reality to spend that on a GPU.
Crazy man !
I have seen it many times blamed on the memory but I don't agree.
The problem is almost identical every time the space invaders fault occurs where as memory problems can be very varied in appearance.
I think the real fault is with something global like a dodgy batch of GPU chips.
If it was memory chips we would be getting the same percentage of problems from the 2070 and 2080 but we don't see that.
It is the memory.
niche card at a niche price for a none gaming niche market. The 24GB of memory is put on there for AI etc and will differentiate still when faster 7nm products come out soon. It would pay to wait and see for any gamer
So why don't the 2070 and 2080 suffer as many faults as the 2080 Ti.
They all use the same memory.
It's effectively a part number (and not even the full one) so I don't think it's a trademark issue.I was thinking about the specs of the TU100 but found that Lian Li have already trademarked TU100 - it's a mini-tower case with a handle - so I'm guessing that TU102 is the full fat chip.
But surely it will be a while yet until Nvidia release the next series’s of gpu’s?
I ordered one to compare against my SLI 2080 Ti setup. Not totally sold on SLI. Can always get the second RTX Titan if needed. Anyone heard anything about water blocks? I'd imagine a 2080 ti block would fit, unless the memory chips have a different height since they are of a different type.
I asked to be notified when in stock (don't know why as not buying one), never had the email. Looks like they're available to order.
Think of volumes sold, IC population, lower TDP. The space invaders on display are synonymous with VRAM corruption.
I did.
2070 and 2080 cards will likely outsell the 2080 Ti quite easily though not for people on this forum.
I am not an expert on memory chips but I think they will be operating under very similar conditions (voltages, temps, workloads) whether they are on any of the 20XX cards.
.Then you may have to rethink how you came to surmise it's not the memory, Kaap. Other SKU are failing, too.
NVIDIA Titan RTX 3DMark Performance Unveiled – Scores Over 40,000 Graphics Points in Firestrike When Overclocked Under Watercooling
https://wccftech.com/nvidia-titan-rtx-turing-flagship-graphics-card-benchmark-3dmark-unveiled/
