- 23 Feb 2009
- Bournemouth
To whoever is reading this,
Which display port cable for a 144hz monitor would you recommend?
Going with this monitor you see > https://www.overclockers.co.uk/sams...c4cPvpj39yumty4ZpWMoKIRsoVgIn8ecu3wh2qRfgPseE
At the moment i have a nvidia gpu the gtx 1070 so freesync won't work but will it run at 144hz more importantly?
The reason being is that i want a cable that supports up to 144hz you see.
Thanks for any advise,
Dan.
Dan.
