Gave the R5 a run on the turbo to start getting the fit and check gears.
It’s so quiet! Quieter than any other bike I’ve built.
Seatpost up, bars down, bar angle, seat up more, bars down more! Seat forwards a touch. Getting there! Maybe go to a 120mm stem but will have to run the fit calculator. It’s only a 110 -6 on there so not super aggressive at the moment.
Riding the TT for the last 5 months even not a lot has obviously built some core strength.
I am quite close to the seatpost insertion limit. It is still inside the frame but I guess I only have 10-15mm to play with, my old frame could run a lot more but then that was a traditional round post from 3T. This is bespoke Cervelo. I’m not sure it could be head games but I’m sure I can see slight movement in it.
