That would have likely gotten some refurbished business laptop with mostly better everything, except more or less worn battery.
Some electrical safety authorities might be interested in testing that AC adapter if it's sold by UK shop.
Not sure what's UK's equivalent for Finnish
Tukes.
Just few days ago in Finnish tech forum one user measured
some Silvercrest branded USB charger giving 70V AC from ground of output.
He first noticed problem from getting shocked when answering to phone connected to charger after coming out from shower.
(humid/wet skin has lot lower resistance)
He measured also handfull of other such chargers and one had 24V in output ground.
(others 0 to 5V)
And Apple certainly uses very cheap manufactured stuff, so I wouldn't wonder similar problems in their chargers.
Unless it's their own bad design. They're very experienced in making and selling
crap designs under shiny surface.
There's simply no trusting to safety of cheap whatever brand stuff.
Like lack of PFC being the smallest worry in this, with no actual grounding of metal case, while lacking plastic insulation sheet under PCB:
Wouldn't wonder any if also physical separation and insulation strength between primary and secondary fails to meet safety requirements.
(insulation must keep 3kV to input separated from low voltage output)
If you just Google you'll find cases of people getting electrocuted by trash AC adapter leaking AC through.
https://www.thejournal.ie/woman-electrocuted-usb-charger-1540800-Jun2014/
https://www.dailymail.co.uk/news/ar...wearing-headphones-phone-plugged-charger.html
Class II applies only to AC adapter.
Laptop itself is Class III appliance and should never see any voltage remotely close to mains voltage.
That's why they can have metal chassis instead of always needing full plastic/insulating material shell.
