New build for a friend's son - little out of the loop
17 Jan 2009
Hi guys.
So I've agreed to put together a PC for a friend's son, but I'm a bit out of the loop on what's good at the moment. Haven't done any major upgrades to my own PC in a few years.
The budget is £750 but she's told me she's willing to go up to £900 if it makes a big difference to the power/longevity of the machine.
Peripherals (monitor/mouse/keyboard) are taken care of so looking at the case and internals.
He'll be using it for general school work but also for games like fortnite, rainbow six and possibly some other newer games. Hoping to get some components which will last a good few years without needing a major upgrade. Also would like some sort of LED system as he'd like to see the internal components through a side window.
Could anyone help with some suggestions for a build? Would greatly appreciate it.
Cheers guys and Merry Christmas!
I think you'd be fine going for something like an R5 2600 + 580 8GB or 1060 6GB. Add a Hyper 212 Evo or similar and you'll be able to get the CPU to 3.9 GHz stable at least.
If budget allows, I'd aim for 16GB of DDR4, I believe the Samsung based stuff works best with Ryzen?
Then you just need to find a half decent motherboard, PSU and storage :)
Oh and a case of choice
