Blue, the 79220B, can get off with it in more options imoNice discount.
Did you get the Bronze Bucherer blue Special Edition or the standard blue bezel version?
This is what I have and I love it. I picked it up crazy good price as a dealer took it in part ex. I paid 1200 for it and know I could turn a decent profit on it, but then I'd want anotherBlue, the 79220B, can get off with it in more options imo![]()
OOft, that's a great buy.This is what I have and I love it. I picked it up crazy good price as a dealer took it in part ex. I paid 1200 for it and know I could turn a decent profit on it, but then I'd want another![]()
10-12% unless you're after the new GMT or 58
I managed 15% off a North Flag last week.
Where please, I fancy the north flag, thanks.
That’s a really nice and historic piece. How much did it set you back? If you don’t mind me asking.Latest acquisition - 1967 Bulova Accutron 214 Spaceview - tuning fork tech!
Case diameter is only a tiny part of the story - dial to case ratio also influences things (a larger dial in a smaller case will wear larger than a relatively smaller dial in a larger case), as does the visible parts of the case (bezel design can mean the case appears smaller/larger), as do colours...and especially lug to lug distance which can sometimes mean a smaller case appears out of proportion with everything else. Unfortunately these dimensions are rarely reported. You really need to try them on to see how they wear on your wrist.Actually just found this one https://www.creationwatches.com/pro...tic-black-leather-strap-mens-watch-14746.html
37mm face, I only have small wrists so should be a better fit for me I would imagine. All of the metal strap ones seem to be 42-25mm that would be on the large side I assume and would likely look daft on my wrist haha.
I might get this one with the leather strap and get a second NATO strap for everyday use (my job would suit the NATO strap better for work).
I can then look more into it to get a really nice on. It does seem like these are the go to entry automatics though!
Do you mean a diver with a date function? If so, you're really spoilt for choice, just give your budget and there can be plenty of suggestions.I fancy a submariner, Omega's a nice but I'm drawn by a Rolex date, although they're very expensive. Any other brands to look at?
Probably around £3-4k.Do you mean a diver with a date function? If so, you're really spoilt for choice, just give your budget and there can be plenty of suggestions.
If you mean a Submariner Date, then there's only one option...Rolex as that's their model and theirs alone. Tudor did do a Submariner with a date function (when the two brands were more intertwined), but they're getting up there in cost too.
If you want the sub look but don't want to pay for it and you are happy to have one without the Rolex name on it then, the Ginault Ocean Rover is meant to be very nice.
You already mentioned the prime watch within your budget - the Omega Seamaster. It was revised last year so is very fresh, or if you prefer the older 2012 model then check out used versions.Probably around £3-4k.
