Ok silly thread title, forgive me. I am after a new wok and need suggestions.
First to mention I have an induction hob, so obviously would need to work on that and have a flat bottom, I also prefer ones with more curved edges, I have seen some in a shop today that are almost like pans the sides go up so steeply.
I have had a few Wok's, first was a traditional carbon steel wok I got from a chinese shop, was ok, but the base warped making it not flat, which made it difficult to use on the flat surface, the other thing with the carbon steel is being thin, the heat kinda just went straight through it, and it got very hot at the bottom, without the sides getting to hot, so you ended up easily burning the base. It also, being carbon steel needed seasoning and honestly prefer a more maintenance free one.
Second one I tried has ceramic surface, I like the cooking surface, and its heavier so radiates the heat through better, the only issue is whatever is it made of doesnt react very well to my hob, meaning that even if I put it on max heat (and leave it for 5 minutes) it still doesnt get anywhere near hot enough to use it effectively as a wok.
So, I though I would turn to the OC experts here, and take suggestions.
Budget, whatever, ideally about £50, if I can spend less and get a good one that's bonus.
... see earlier thread discussion
