Caporegime
- 13 May 2003
- Warwickshire
What device were those taken with @RJC? I'll tell you why I'm asking once you've answered...
Did you knock that bench up yourself?
Can I ask what those pump type things on the wall are please?Bought it from here:
https://mctimberproducts.co.uk/
Was tempted to build one from scratch but for £55 I though it was not too bad, just needed to assemble myself.
So you’re worth a call when my fridge packs up then?They are gauges to put on refrigeration systems, The Green box on the lower shelf has another set in plus my fittings for checking car A/C.
Canned anal lube?
It's pretty slippery, you could probably use it for that if you wantCanned anal lube?
I wish, I could use some of thatI was going with spray-on hair.
It has the opposite effect to mustard when smeared on your cheeks.....Is it like a special mustard powder @Feek?
