- 4 Aug 2007
- Wilds of suffolk
Thanks for this, as it happens I spoke to them on the phone earlier and learnt the same thing...I think I'm probably just going to accumulate £500+ every-other-month so that I can pay with the term-reduction option (to me that feels like the method that results in the biggest saving in the end)... Keeping the term the same and not recalculating feels like it's just saving into a 0% interest savings account until the end of the next deal/rate change, isn't it?
No, because once its paid its paid, there will be a small sum to pay to end the mortgage, they will write to you once you approach getting to zero. If you change your term your tied to the new end of term. If you keep the term the same and you do use some of your overpayment reserve (for whatever reason) then you will not need to increase your payments to cover the reduced term. If you lower the term, your committing to clearing by that date, so if you used your overpayment reserve you would need to increase your payments.
Originally you only had the option to reduce the term or reduce the payments. Now you can specifically keep the term and the payments, so you just gain more flexibility by selecting that option.
You can in fact also change it online at any time, tick one of 3 boxes and click select. If you make an overpayment and reduce the term they will write to you each overpayment (of more than £500) and tell you your new end date.
The interest is calculated daily on the outstanding balance, so your literally saving money the moment you make an overpayment. Well I think technically they apply it the following day.
My overpayments I just send via online banking, quite easy, instructions are on their site. I paid something like £50 the first time, just to be sure then wacked it up afterwards.
