564 or 556 amd
1 Aug 2014
york
will be gaming at 1080p. Can’t make my mind up and don’t really know the difference. What I’m asking is. Is the £80 worth it? Will be running at ryzen 2700x with 3200mhz ram so yeah thanks for the help
I'm going to put my neck on the line and say are you are asking if a vega 64 is worth more than vega 56. The simple answer is it depends.
If you are on a high refresh monitor and dont mind spending 15 minutes tuning I would say yes. If you are playing at 1080 60hz and would rather not have a play get the v56.
My bad man I totally fluffed the title. Yes I was meaning the vega graphics card. I’m on a normal 1080p monitor with not much experience over clocking
Vega 56 are great card if you can pick up as near to £300 as possible. Also consider the 590 or 580 as they too will play 1080 just fine.
For longevity though if you upgrade the display sometime in the future you would want the vega.
