Computer Keep Sleeping, even when I tell it not to
11 Jun 2003
Hampshire
Hello gents,
I've set the Power Plan to Performance (and gone back to check it's still set), I've changed the plan settings and made sure nothing switches off except the monitor. I've set the same settings in the Balanced plan too.
Yet every time I come back to my PC, it's in deep sleep, all the fans ore off and a move of the mouse is required to wake it up. When this happens I change my power plan and it's back on balanced.
I'm wondering if I need to change something in the bios. Super frustrating at this point, any ideas?
Spec :
Maximus X Formula
8700K @ 4.7Ghz
GTX 1080 @ 2140Mhz
Corsair HX800i
WC Loop
The PC fulfills sporadic server duties when I'm not using, hence my reasoning for wanting it on.
