- 14 Apr 2014
- Hampshire
Hi all,
I'll keep this brief.
Younger brother has a PC. He was playing a game when it locked up. Tried turning off using button, nothing, so he switched it off on the PSU. Upon switching it on again, the PC wouldn't turn on. I knew that the PSU would be right on the limit when installing the GPU, but he recently watched a video on GPU overclocking, and while he denies trying to actually overclock it, I suspect he has (he's that type of kid
) and I suspect this has tipped it over the edge power draw wise.
It's a 500W EVGA PSU I believe (only their basic one) that was bought when PC was originally built (strict budget). At first glance it, looks enough for the specs below, but when I installed it I remembered checking rails etc and noticed the primary one for the PCI power was quite low, and thought it would be on its limit.
Specs:
i5 4460
GTX 780 GHz
500GB HDD
8GB DDR3
Experience tells me the PSU is most likely dead, as no sign of life. I've yet to start properly diagnosing.
If it is indeed the PSU, what would you recommend for around £60 - budget is tight so please don't recommend £80 PSUs
Edit:
Thanks in advance for any ideas/recommendations!
Specs:
i5 4460
GTX 780 GHz
500GB HDD
8GB DDR3
Edit:
