Taking ownership of C:\ should come with a huge warning or not be a thing
25 Nov 2005
Don't do it, it should not even be an option for how destructive it is to windows where you can't even run the reset this PC in recovery because none of the files work any more
Fortunately using a flash boot of ubuntu I was able to save all important files but damn I could have lost everything
And yes, I was foolish enough to not do a recent backup as such it was simpler to just reinstall win10 fresh than use a 5month backup because I'd purged quite a lot in 5 months and installed a tonne of new stuff
A little harder to do these days accidentally but it used to be possible to screw a Linux installation up the same way with a recursive chmod or rm if you accidentally hit enter after a /
:D Thanks for the info, why did you do it in the first place though that’s the question lol
I had some audio plugins that weren't working
They worked when I took ownership until I restarted the comp and everything went to ****
2 days to reinstall everything, also thought I'd lost some crypto but fortunately salvaged the wallet, now I'm just taking ownership of the folders the plugins are in instead of whole drive
Seem to have everything back to normal "touch wood"
Not sure why you would even touch anything to do with the root C:\ on a home machine. It's only folders inside you would generally touch if ever even needed. I never had anything to do with setting anything on the C:\ in 25 years in IT.
It didn't have any warnings, so I thought it would be okay
For how utterly destructive it actually is I don't even know why it's an option :confused:
By the point of being able to change ownership of something you're already deep within Advanced Security Settings and through UAC elevation which should really be warning enough that the thing you're playing around with probably needs a level of understanding as to what it is you're actually going to be doing before doing that thing. Presumably you also replaced the owner on all subcontainers and objects too for good measure.
Hard lesson learned I guess.
It's an option for when you do need to change permissions.
I don't understand why it is an option though because it corrupts all system files, including backups and the files needed to do factory reset too and from google there seems to be zero way to reset the damage unless you do a fresh install and manage to find a way to access the files to backup the important stuff
I've somehow managed to free up 150gig though on C: since the fresh install, so there is some reward for breaking windows along with the learning experience
It's an option because those can occasionally be used to fix the PC - If you know what you are doing but few people ever mess about with root permissions as it's incredibly unlikely you'd need to alter them on.
It doesn’t corrupt anything unless you touch it.
