Hello, guys, I think I know what the problem is but will need a second opinion. In short, I gave my sister EVGA GTX 780 SC ACX in November 2018. It ran without any issues until today where weird artifacts started to appear (checkerboard, green/purple artifacts, missing and/or different color textures) and games started to crash (not all the time).
I've cleaned the GPU and replaced the thermal paste before giving it to my sister. Yet I haven't replaced thermal pads on vrms and memory as I was lazy to check them. I hope this is not a bad memory = gpu on its way out. I attach a link to youtube to show those artifacts.
Artifacts appear between 0:01 and 0:10, then from 0:38 to 0:42. The gameplay of assassins creed from 1:50 is fine as you can see but sometimes there are green/black lines and/or checkerboard full/partial)
I've plugged the GPU to my rig with the same issue, yet raising the fan speed to static 65% caused fewer artifacts. The card idles at 29C and 78C at load (assassin creed odyssey) so I guess thermal performance is not an issue. Maybe dried out thermal pads?
All help and advice will be appreciated! Thanks in advance
UPDATE another example from cs go
0:18 to 0:25 and from 1:40
