Hi, basically as the title says. I'm going to do both but unsure which would be best to do first as there will probably be a fair few months between upgrades, my current system is,
i5 4460
8GB RAM
GTX 1060 6GB
I'm considering a GTX 1070ti or a GTX 2060, price dependent (Seems I could get either for around the same cost, so whatever is the better option), for the GPU upgrade.
For the CPU I'd be looking at Ryzen 5 2600 or 2600X most likely, which would mean a new motherboard and RAM (I'd also go from 8gb to 16gb here).
Currently using a 1440p/60hz as my main monitor so ideally I'd like to play on that at 60fps.
Just looking to gather some opinions on what people think would be the best way forward, thanks.
i5 4460
8GB RAM
GTX 1060 6GB
