1080Ti - broken display ports
9 Dec 2006
@ManCave
hey all,
i bought my 1080TI day of release (its a gigabyte aorous) was going to add an extra display today to find out that some ports on my gpu no longer work
main display is 1080p 240hz gsync
my second display is 4K (pg2789AQ) gsync (over DP)
display port #1 works
display port #2 doesn't work
display port 3 #3 doesn't work
HDMI #2 works
HDMI #1 works
tested multiple cables and tested the 1080p screen in all ports #2#3 are dead!
of course the 2nd display works over hdmi but only at 1080p....
what card do you think i should replace the 1080ti with?
will be gaming at 1080p 240hz with a 2950X
good point i thought it was been longer than expected. even so if they replace it with a 2*** which should i except
I wouldn't expect or accept a RTx 2*** as a replacement as the only card with the same amount of Vram as your 1080Ti is the 2080Ti. Anything else like a 2070 or 2080 whilst similar in performance you would be losing a decent amount of vram
