Hello All,
This weekend I impulse bought a new 9900k and Aurous master, cooled by a Corsair H100i. I'm pretty new to overclocking but I have everything up and running - clocked the CPU to 5GHZ (4.7 uncore) @ 1.3 vcore. I'm happy with everything but wanted some advise on a few of things:
I think my overclock is pretty decent; ~mid 30's (C) idle temps and generally under 60 when running Prime95 blend. Do you think it's safe to it a bit push harder? The OC guide I followed stated I shouldn't go over 1.35 vcore; am I safe to get the fastest clock speed at that, as long as I'm getting decent temps?
Secondly, when running blend [in prime] and gaming my CPU temps are OK but the Small FTTs test kills my PC instantly. Is this because it runs AVX commands? There's an offset in my Bios, should I configure that to keep the test stable?
Lastly, in my bios settings for XMP I only have a single profile option which I selected, with the correct speed for my memory (3200) and everything else is set to auto. Is this enough? I have read something about tight/loose timings which is more important then speed. Is this something I need to worry about? It's a gskill 16gb kit.
Thanks in advance! It's fun to start pushing my system.
