Hi,
As the title really, deciding between the above 2 AOI in either 240mm or 360mm. The OCUK ones a cheaper but have less warranty. Can't find many reviews on them so was wondering it anyone could advised on the differences or which is better?
Will be going into a Ryzen build, only 2600 at the minute but plan to upgrade to Zen 2 when it is out.
Cheers,
Rhys
Cheers,
Rhys
All AIOs I know of that are not CLC publish the pump flow rate and lift specifications so we know how much coolant the flow.
