New build 2,500£
18 Jan 2019
Hi I have never build gaming pc before,I managed to do a configuration,but I just want to know if everything is corect or do I need to make any changes.I am open to any suggestions and help.I am going to use the pc strictly for gaming.My budget is around 2.500£ so I need to down the total if possible.Not sure about the video card as well. Thanks
My basket at Overclockers UK:
Total: £2,695.68 (includes shipping: £15.90)​
@Ivchom
System looks damn good, .Recommended something similar before but on a cheaper scale
https://forums.overclockers.co.uk/posts/32429419
Heard Gigabytes screen is being tested for G-sync as was released/revealed after Nvidia dropped that little bombshell .
Resident Gigabyte / Aorus rep @GIGA-Man might be able to supply some info on it .
Few changes, Aorus RGB ram - it's Samsung B-Die and should hit 3644 hz with timings left exactly the same .
Aorus non Xtreme, no difference in card bar the clock speed - just manually overclock and don't forget to register 4 ye UK warranty .
Switched board from ultra to WiFi pro. Underneath the boards are pretty much the same, 12+1 VRM set up, heatsink and looks are different but performs the same .
Pushed larger 1TB SSD over smaller SSD and HDD. HDD are so cheap can add it to the system any time down the line . Always push largest SSD you can get and add HDD when you need it /can
You won't notice a difference gaming with nvme Vs sata 3 SSD.. if your doing data work then yes !
Total: £2,700.77 (includes shipping: £15.90)
I think 8 pack 3200hz Samsung B-Die is on sale for £170 odd as well :)
@orbitalwalsh thank you for the reply and the suggestions you made are really on point.One more question though, do you think it will be wise to go with Zotac GeForce RTX 2070 AMP Extreme Core Edition to save a few £ or if you have another suggestion ?Thanks
@lee32uk thank you for the alternative choice you suggested,but always been an Intel fan !
Fair enough. Ryzen is the value king though :cool:
Closer to your £1500 budget if you don't mind a different case, SSD and gpu model (Still a 4 yr warranty when registered). The Define C and Phanteks Enthoo Pro Glass/Pro M Glass are also nice cases imo.
Total: £2,515.98 (includes shipping: £13.20)
Rtx 2070 is powerful, if your pushing FPS go rtx 2080.
If you need to save cash, Gaming OC still has 4 year warranty and triple 2.5slot cooler
Or as Lee has mentioned about, save some cash with the case. Still damn good case
@Ivchom
A cheaper case such as the Fractal Meshify C would knock about £90 odd off straight away. You could also go with a smaller power supply such as the Antec Earthwatts Gold 650W.
That should knock around £150 off in total, bringing it closer to your budget. You will have to request the changes though as these parts are not listed in the configurator.
Thank you both for the help,but i decided to go with a prebuilt.I need one more advice from you guys and that is can you help me get this configuration down to 2000£.Thanks looking forward to see your responses @orbitalwalsh @lee32uk.https://www.overclockers.co.uk/ocuk...S2?v_bmeT2?v.bmfa2?v-bmfT2/27btlE2#(*btlF2#'y
few changes
case, Fractal Design to keep silence and looks - done deal so £64 saving
i7 9700k over 9900k - if your pure gaming, you'll notice LITTLE difference . much like Ryzen 2600 over 2700 . 6 cores/threads is the top end for most recent AAA title games . £74 saving
switching SSD Brand, 1tb from 500GB, extra at £20 extra
Motherboard- from Elite to Ultra, extra £60 but saves spending £21 on NOT HAVING to use a WIFI card which has WORSE PERFORMANCE ! - so £40+
1TB HDD instead of 2TB due to larger SSD which would be used for Games and OS. £21 saving
Focus Plus Plat 850w to Whipser 850w - still a high tier PSU but £30 saving
  • 1 x OcUK Tech Labs Coffee Lake Pro Gaming Configurator = £2,105.82
    • Motherboard:Gigabyte Z390 Aorus Ultra Intel Z390 (Socket 1151) DDR4 ATX Motherboard
    • Processor:Intel Core i7-9700K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM
    • CPU Cooler:be quiet! Dark Rock Pro 4 CPU Cooler
    • Memory:Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30
    • M.2 Solid State Drive **For Operating System If Selected**:Unwanted
    • Solid State Drive 1:TeamGroup 1TB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
    • Solid State Drive 2:Unwanted
    • Mechanical Hard Drive 1:Seagate BarraCuda 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - *System Stock*
    • Mechanical Hard Drive 2:Unwanted
    • Optical Drive **Please Check Chassis Support**:Unwanted
    • Power Supply:Bitfenix Whisper M Series 850W 80 Plus Gold Modular Power Supply
    • Soundcard:Unwanted
    • Network Adapter:Unwanted
    • Case Lighting:Unwanted
    • Operating System:Microsoft Windows 10 Home Advanced - Systems
    • Security Software:Unwanted
    • Build Time:Standard Build Systems - Dispatched in approx 7 working days
    • Headset:Unwanted
    • Keyboard:Unwanted
    • Mouse:Unwanted
    • Speakers:Unwanted
    • Monitor:Unwanted
    • Gaming Chair:Unwanted
    • Case:Fractal Design Define R6 Midi Tower Case - Black Tempered Glass
    • Graphics:Palit GeForce RTX 2080 Gaming Pro OC 8192MB GDDR6 PCI-Express Graphics Card
    • Graphics 2 (SLI/Crossfire):Unwanted
Total: £2,119.92 (includes shipping: £14.10)​
