HG Wells already went over this in his documentary "The Time Machine" where it showed that you always stay in the same point in space relative to everything around you, you just shift through time.
But seeing as ground level changes over time you could theoretically end up either in the air or buried in the ground if you stay in the same relative point.HG Wells already went over this in his documentary "The Time Machine" where it showed that you always stay in the same point in space relative to everything around you, you just shift through time.
It seems to be a question few ever ask when it comes to time travel and most don't consider that everything in space is constantly moving
Even if I went back in time by a day, the Earth have changed position by 1.5million miles![]()
If time travel were possible and time is relative
If you went back in time do you go back in time to the spot where you were in the future when you started to go back in time
Or do you go to a new spot relative to the Earths spin in reverse by however many years you have gone back ?
Would the same apply to any point in space or only objects influenced by mavity ?
For instance if I went half way between the Earth and Moon and went back in time 1billion years, I could still be in the same point in space but the Earth and Moon will be in a different location to where it was before I went back in time because of their orbits around the sun and the solar systems orbit around the galaxy
Or would I always be half way between the Earth and Moon ?
What happens if you go back before the Earth or Solar system even existed ?
I think logically your point in space would stay in the same, but everything else would be at a completely different point in space depending on rate of orbit/spin, if you could reference your point in space
You're expanding on my musings in the terminator thread aren't you?![]()
Time travel is relative, you can only go forward not back.
Says who?
Says relativity.
The TARDIS is clever. If you tell it to go between the earth and the moon, it would go there*
If you then told it to skip forward 150 billion years, you would end up 150 billion years in the future in the same location*
*this is assuming the TARDIS is actually controllable. What would probably happen is that you'd tell it to go to Croydon and end up in Aberdeen.
Thought that might be when NSYNC formed but it seems that was 1995. What's that date then?April 12th, 1996.
