Don
- 20 Oct 2002
- Oxfordshire / Bucks
my RX580 fans are at max speed when i play games
need to change the temp/fan speeds
thanks
thanks
thanks guys
under volt using wattman?
Yes, you can undervolt via Wattman as well.
The default stock voltages that are applied from factory are often in the 1.15 to 1.2v region, especially for P states 5 to 7, which is when your GPU is going to being most stressed. The only thing is, none of the RX580's need this much power to do their default factory clocks. So unless if you're heavily OC'ing that card a lot in the first place, you're much better served by lowering the appropriate P state voltage to a lower level and enjoy relatively the same performance and much lower temps too.
Inside Wattman, adjust the Global Settings in the Gaming section of the AMD Drivers. There, select Global Wattman.
Adjust the GPU Voltage from automatic to manual.
For States 5, 6 and 7. Try something like 1100mV (1.1V) first to make sure it's still stable (the reason for this is because all cards are different, so what mine can you yours may not, etc).
Adjust the GPU Memory Voltage from automatic to manual.
Enter into State 2 850mV.
If you want, you can adjust the Frequency of your GPU memory later after you've got some better temps locked down.
Next, change Fan Speed from automatic to manual.
You'll have to play around with this bit next for your own tastes, and adjust for sound/temps. I've personally used 1300 min and 1500 max for these entries for the Fan Speed.
Temperature I've left at automatic, but the range in my card is defaulted to 90C max temps and 80C for the target temps.
Finally, adjust the Power Limit % to +50. This will prevent your card from throttling itself in heavy usage.
Again, you may need to adjust some of the numbers to suit your card. But you'll find a world of difference in temps after undervolting the card.
