Do I need the retail version of Windows 10 to run in a virtual machine?
1 Nov 2007
England
I already have a copy of Windows 10 Pro which I use in a virtual machine, but I need another Windows 10 virtual machine. Would I be OK to use an OEM version of Windows 10 or do I need to have the retail version?
What's the reason? As you probably be better off using the trial versions in a VM.
Legally, you need a licenced version. In practice you can download Windows install media from Microsoft and leave it unlicenced and just tolerate a few things such as occasional reminders and not being able to customise your Start menu. What are your actual needs? What I've found recently is the joy of Docker on Windows. There are Windows images (including Nano) that you can download and fire up and you don't need a licence for that. You can even distribute the images so long as their primary purpose is other than providing Windows functionality.
But if you're doing VMs then yes, Microsoft do not treat an install on a VM any differently than an install on real hardware. And an OEM version will consider the VM's hardware signature to be it's true install fwiw.
