I can’t decide on which GFX card for this build, please help.
The performance of Intel with these programs is the main reason I have decided to go the i9 9900k route. Which AIO would you recommend for decent performance till I get round to doing the custom loop?
My basket at Overclockers UK:
Total: £407.93 (includes shipping: £10.50)​
Thanks Orbital, I had been looking at Corsair options but like the look and reviews of the be quiet one you linked above.
https://www.overclockers.co.uk/cors...uid-cooler-360mm-cw-9060031-ww-hs-03l-cs.html
corsair isn't to bad. least from asetek units- they use the latest version for Pump design, NZXT units use the older Gen still
fans of the corsair are better then the eisbaer and pure wings of bequiet . alphacool actually swapping their fans for bequiets purewings ! personally the silent loop should have had showdow wings or silent wings and matched NZXT/Corsair price points exactly!
Pumps are better and rads are better designed but FPI is lower, due to copper design and aiming for lower sound so in cases and be slightly warmer then the corsair unit which uses brute strength
