Hello, I recently bought a PC second hand and it came in a Corsair 570X. I removed the AMD motherboard last week and today I've been putting in my Intel build. While plugging everything back in I noticed that the RGB Corsair fans each have two cables, one is a standard 3pin cable that goes to the motherboard, and the other is a 4 pin type that was plugged into the included Corsair Fan controller that comes with the case.
Am I right in thinking I only need to plug in the 4 pin cables to the Fan controller and don't need to connect the 3pins to the headers on the motherboard? Or has the 3 pin got something to do with the RGB? Its my first time using RGB fans or even PWM fans for that matter, so I want to make sure I set it up right.
