Power color 290X hitting 94c
I did actually try both switches but the temps are the exact same. Right now the card is idle and it's at 71c. I don't have a lot of air flow on my case but I have a top fan and exhaust fan
I thought pasting it would have bought the temp down some
I thought there was a feature with reference 290s and 290Xs where it lets the card get to 94ºC before it starts ramping the fan up?
I found this usually resulted in throttling though as the fan didn't spin fast enough soon enough, so used MSI Afterburner to set a custom fan profile.
I set a custom fan curve, 10% intervals for every 10 degrees. Is the fan on these cards meant to be this loud? It sounds like a jet
I recently bought a used power color 290x. First thing I noticed was that the card was running at 94c during games, took the cooler off and the paste was all dry. Applied new paste but it's done nothing, card is still hitting 94c. The cooler seems to be working fine as I can hear it
Any idea what could be causing it to get so hot even after new paste
That's a fully working 290X.
