Hi all,
Just received my Nitro+ Vega 64 GPU (order from Overclockers) and there are no fan cables included even though the instruction shows it needs to be connected. The problem is that is it requires 4 pins female to female cable, which I cannot find anywhere that sells this.
My questions are:
i. Should the GPU comes with fan cables? There is nothing apart from a few leaflets of instruction and the GPU support bracket in the box. Seems quite stingy consider this is a premium product.
ii. If not, where can I buy them? Already looked on Amazon, eBay and a Google search.
iii. If I can't buy them, I was thinking of getting some 4 pins extension cables and snip off the male connector (you know what I mean
). Then replace the end with a female connector, my question is, is it direct wire connection from the other end, i.e. pin 1 to pin 1, 2 to 2, etc.
Thanks in advance.
My questions are:
Thanks in advance.
