 - 27 Mar 2003
Over the past couple of months I have been slowly replacing all my case fans due to annoying intermittent fan whine and given that this the last fan and I still have the noise I have to conclude that this is the fan that ultimately where this noise is coming from.
So my questions are:
1) How easy is it to replace the fans on this cooler?
2) It seems the inner fan on this is a 135mm fan and I don't see that as option to replace so would it be ok to put a 140 or 120mm in the middle?
All my other fans I have replaced with Noctua A8 PWM Fan's so I am looking to try and keep everything as quiet as possible.
Alternatively would it be probably time to move to an AIO watercooling solution? (this is for an i7 5820K)
, but non clean air can give you odd noise artifacts.
