if you're running a high end GPU, then better to use 2 separate cables rather than 1 cable, as @bremen1874 points out.Can I use those extra plugs to replace the extra psu cable coming from the psu?
and welcome to the pc building world![]()
to be honest, extension cables are mostly for aesthetics rather than anything more functional (unless you know, you actually need the cables to be extended)My bad I honestly didn't know.
Im not comparing prices or anything, I check from that site because I need it shipped to Hong Kong which is abit weird I guess.
Rx 580 is still ok to use 1 cable. It's the higher draw cards that ideally should use 2 cables. Heat = I^2 * R. So if the wires have small gauges, there's a lot of resistance and heat. Can melt the wires or connectors.Sorry to hijack but at which point would you say use 2 cable sets instead of 1 set from the PSU (rx580) ?
Thanks
Its putting pressure on the GPU and also cpu power socket
