Do I need to install my AIO cooler just for Windows install>?
26 Jan 2010
So have a new mother board
a new cpu
a new m.2 drive
from my old case i will transfer PSU and GPU, all i need to do is safely install windows till i start transferring to my new case new build
I dont want to install the cooler, do i need to just for windows? will i burn out my cpu if i dont?
can i just install windows with no cooler?
You will need a cooler. The cpu will overheat and throttle heavily or completely shut down pretty quickly. There's a good risk of damage to your cpu using it without a cooler.
What's the reason for not wanting to fit the AIO?
basically got a X299 mobo and a 7920x with a 1tb m.2, i want to just install windows to make sure it boots up fine and its all good to go before I start transferring everything else, if i hit issues then I'll just use the old build till I correct the issues, as i have only one cooler swapping over the AIO will be a headache
Im pretty sure im gonna face boot issues, will only connect one m.2 and boot windows from a usb drive
I don't think you should encounter issues to the point that you'd need to go back to your old system though. Worst case scenario, swap the AIO over and buy a dirt cheap cooler for the old rig?`
You won’t have issues, make a boot usb of it and install... format the drive first if it has already got windows on it and should be easy but all you need to do is hit bios and boot from the right device (usb).
Also isn’t the point of AIOs that it’s not a faff it’s the same as mounting a normal cooler, quick job no?
buy a stock intel cooler for £3 and stick windows on when the stock cooler is on. It'll be loud but it's only temporary
You have a £1000 processor and a £300+ motherboard and you're prepared to risk destroying it because you're too lazy to just bolt your AIO to it and leave it hanging? If you just want to install Windows to test then don't even build the system, just have the motherboard sat on your desk with the AIO hanging off the side.
It takes mere moments to bolt on the AIO, do the test then clean and reapply TIM later on. What's the point in cutting corners?
Bananas, isn’t it. :p
I was going to post EXACTLY the same thing :)
I would overclock the cpu so you can get windows installed faster, 5ghz should do the trick but might need a voltage bump to get there.
Seriously installing an AIO on lga 2011, 2011v2, 2066 couldn't be easier. The already have backplates on. It's just 4 screws and then securing them on the top and that's it. It's a 30sec. install if you just put it all on the table.
