So I was thinking about building a Windows 98 gaming machine.
The best candidate would be an Intel Pentium III motherboard or whole computer but old computers like Pentium III are hard to find and when they do come up on ebay there have a high price and a lot of the time they are listed as untested or don't work at all, most of them are over priced scrap and even if they do work its only a matter of time before they die.
A newer board like a socket 478 motherboard that has been tested with an Intel Pentium 4 processor at 1.5 GHz is perfect and parts are cheap... for now.
There is already a great interest in Pentium 4 computers so it wont be long before those start going for a lot of money.
I could get a socket 478 motherboard for 12 pounds tested and working from a trusted seller.
I can get my 1.5GHz processor for 2 pounds tested and working I'd buy a couple of those 1.5 GHz processors seeing that they are cheap right now.
I already have a box of AGP videos cards so I'll go with a GeForce AGP that I have.
I also have a couple sound blaster cards
I've also got plenty of working ATX power supplies and CD/DVD drives and a few floppy drives so once I have the motherboard and processor I will just need to get a retro PC case...
I've got lots of spare fans as well. I do have a couple spare CPU heat sinks somewhere but I don't know where I've put them so I may have to buy a CPU heat sink and cooler. I have some thermal paste as well and I've got plenty of old DDR RAM so I'll have 2X 256 MB RAM making 512MB RAM which is plenty for Windows 98.
Even though this is already a cheap project its always good to keep costs down, so I will try to find a board that has its processor cooler still on it, that way I wont have to buy the CPU cooler separately.
Now with the motherboard depending on what model of socket 478 motherboard I get I'll have to do some research beforehand to make sure that Windows 98 can run natively without hunting down chip set drivers for the motherboard which is always a nightmare.
Generally with most socket 478 motherboards from 2000 to 2004 I should be good to go. I'll be using Windows 98 SE then I'll install the service pack 3 which is the latest update for Windows 98SE
Something like 2GHz+ / 533MHz FSB CPUs from a year or two later. But what 5GHz processors are you talking about? Also what AGP cards do you have? This also might be a stupid suggestion but just check the CPUs you're getting are for Socket 478 and not Socket 423 which only took those early P4s and lasted about 5 minutes.
